After the natty-to-oneiric upgrade, I observe a sound problem in the browser - most likely related to flash. I have tested both youtube videos and mp3 streamers, both are equally mute. Other sounds (system notification, amarok) work fine.
Here are some details. I run firefox 7.01, and according to about
lugins, I am using libflashplayer.so from
Shockwave Flash 11.0 r1. I did a reinstall of the flash plugin (package adobe-flashplugin from the oneiric repository), but to no avail.
I used to have other sound problems in the past, which were related to having the wrong sound channel attached to the earphone plug. Anyway, I think I figured this one out but it does not help with the flash problem. If I look at the 'playback streams' in the mixer applet, I notice that the amarok sound is indicated as a stream on its own (called Amarok: 'song title') while playing sound in the browser creates another stream called 'ALSA plugin [plugin container] ALSA playback'. And yes, this stream is not muted and has a non-zero volume set.
I must admit that I am a total idiot when it comes to sound, I could not tell a PHONON from an ALSA or a PULSE-AUDIO.
any idea what I could do?
