Hi....
Well, I was in the process of researching a solution for you and it looks like you have solved the problem.
But, in case you have the same problems in the future, another option is to replace KNetwork Manager with wicd, as mentioned here. Instructions on doing this correctly can be found (somewhat) here and here.
Not sure why your connection glitched up though...
Regards...
Regards...
