[Solved] Problem upgrade from 10.10 with kde 4.6.2 backport
    Re: [Solved] Problem upgrade from 10.10 with kde 4.6.2 backport
    Originally posted by Snowhog
    Several 'basic' rules one should observe before attempting a version upgrade.
    1) Ensure you are fully dist-upgraded in the current version you are running
    then,
    2) Disable all non-standard Ubuntu repositories (PPAs and/or 'other' repos)
    then,
    Open Software Sources and in the Updates Tab set Release upgrade to Normal Releases
    save and close, then,
    3) Open a terminal and type:
    This has always worked for me. I simply do no trust using KPackagekit for this (I don't use a graphical package manager at all for actual package management).
    Tried what you suggested and got the following error:
    Calculating upgrade... Failed
    openoffice.org-common : Breaks: openoffice.org-dmaths (< 1:3.3.0-7) but 3.2-1 is to be installed
    E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
    Any suggestions on how to fix??
      Likely you have some third-party/non-standard repositories active. If so, you need to comment them so they are not used during the package update/dist-upgrade steps.
