I just installed my Kubuntu, but before, ma network crashe, so while the installation during, there was no Internet connection. After the setup, I wanted to enable animations, but when I clicked Apply, a tray showed up with this text: The following animations could not be turned on.
There is no details, or explain, just a list from the animations, I wanted.
Can anybody help me, because I likes, if something looks good on computer. I'm using Kubuntu 11.04.(think 32bit) Athlon X2, 64 bit; Windows Xp, as additional OS, .
And an another problem: I've installed Kubuntu 11.04. In april, and after some time, the line, where I can move, close etc. the windows, disappeared. Only this bar. Animations, all KDE working. I solved it with a reinstall, but I like to know, why is this happened.
Oh, one little for the end: I've took the red ball widget to the home screen, and set it to the maximum speed.
And I couldn't delete it, because it' regaining it's power again and again! >
So, do you know an additional way, to delete widgets?
thenks so much for your help!
barnabas02
barnabas02
