Basic informations about the hardware of my notebook HP 625 WT146EA:
CPU AMD Athlon II P320 / 2.1 GHz
RAM 4 GB Technologie DDR3 SDRAM - 1066 MHz
HDD 320 GB - Serial ATA-300 - 5400 rpm
Drive DVD±RW (±R DL) / DVD-RAM - integrated
Video Card ATI Mobility Radeon HD 4200
My problem:
It all began with me trying to install a proprietary video card driver on my working (updated from 10.10) 11.04 64Bit Kubuntu.
After successfully completing the installation and a reboot, I just got a black screen. After many hours of trying to repair this
via the Kubuntu 10.10 Live CD and chroot (tried reinstalling every package, reconfiguring the x server via dpkg / .conf) I finally
gave up and tried to install Kubuntu 11.04 64 Bit from CD - and discovered basically, that Kubuntu 11.04 seems to have this problem embedded.
From the moment I start the Live CD and hit "Enter" on "Start Kubuntu", it shows the loading screen and then...black screen of death.
If I instead install Kubuntu 10.10 from Live CD and update to 11.04 via the paket manager, everything works....as long as I don't hit "Yes" when the question "Do you want to remove unnecessary packages?" pops up after the upgrade to 11.04. If I do - black screen of death.
Even if I install Kubuntu 11.04 via the Alternate CD - installation completed successfully, reboot, black screen of death.
This does also count for the 32 Bit version.
I could now just simply install 10.10, upgrade and keep the "unnecessary" packages, but as this system will soon be my only system in use, I really need some stability.
Anybody here who can help me?
Text is loosely translated from german, so if you don't understand anything, please ask.
Thanks in advance.
My problem:
Thanks in advance.
