Hi all,
pushing the Power Button instead of appear the Windows of "End Session" (Shutdown, Restart, Suspend) kde freeze for about 30 seconds: I cannot use K menu, application bar, sys tray, plamoids (are frozen they also, example: CPU usage plasmoid stops)!
After, sometimes, it's like if nothing will happen, and Kde starts again to work; other times, instead, I've to restart the laptop.
The same thing closing the monitor (I've setted to shutdown system when laptop monitor is closed when system is on).
Is this a bug?
Thank you for any answer
Is this a bug?
