Program Installation: Tk Application problem - DISPLAY
    Hi all,
    I want to install ANSYS 12 on Kubuntu 10.10, but when I input ./INSTALL in the appropriate path that's what I receive:
    Application initialization failed: this isn't a Tk applicationcouldn't connect to display ":0.0" Please set your DISPLAY correctly.
    What can I do?
    Re: Program Installation: Tk Application problem - DISPLAY
    I thought it was solved by copying the folder onto the linux partition from the NTFS, but the problem is still there.
    Any help is appreciated.
