Login screen frozen when running on battery
    I have just upgraded to 10.10 and noticed something weird. Sometimes when I powered on, it would boot up, and when it got the the username / password screen all input was frozen. Pressing the power button didn't offer the shutdown options menu.
    All I could do was power off by holding the power button down for 10 seconds.
    The only way I can have a useable login screen is by having the power connected. I am fine to run on battery once logged in.
    This occurs even with a decent amount of charge left (i.e. still happens at nearly 100%).
    Using a Novatech X16 NV Pro
    Re: Login screen frozen when running on battery
    That is weird -- I don't recall ever seeing this particular problem. It might be helpful to see the details of your hardware, as output by
    lspci -v
    and
    lsusb
    NO, in all likelihood you can restart it with Alt-SysRq R-S-E-I-U-B, and preserve your fileystem's integrity.
    That's odd. It sounds like it is related to the powerdevil settings. Try going into System Settings > Power Management, and changing the default to "Powersave", for both of the first two settings. (Default is for the AC power setting to be "Performance" and the "On Battery" setting to be "Powersave"). Then reboot the system (on battery) and see if there's a change. If there's no improvement, change both of those settings to "Performance" and then see what you get.
    Also, you probably would be wise to fsck the root filesystem partition, at this point -- use a Live CD or booted USB stick.
      lspci -v
      00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
      Subsystem: CLEVO/KAPOK Computer Device 0808
      Flags: bus master, medium devsel, latency 32
      Kernel modules: sis-agp
      00:01.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge (prog-if 00 [Normal decode])
      Flags: bus master, fast devsel, latency 0
      Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
      I/O behind bridge: 00009000-00009fff
      Memory behind bridge: d2000000-d30fffff
      Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
      Capabilities: <access denied>
      Kernel driver in use: pcieport
      Kernel modules: shpchp
      00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
      Flags: bus master, medium devsel, latency 0
      00:03.0 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
      Flags: bus master, medium devsel, latency 32, IRQ 20
      Memory at d3404000 (32-bit, non-prefetchable) [size=4K]
      Kernel driver in use: ohci_hcd
      00:03.1 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
      Flags: bus master, medium devsel, latency 32, IRQ 21
      Memory at d3405000 (32-bit, non-prefetchable) [size=4K]
      00:03.3 USB Controller: Silicon Integrated Systems [SiS] USB 2.0 Controller (prog-if 20 [EHCI])
      Flags: bus master, medium devsel, latency 32, IRQ 22
      Memory at d3406000 (32-bit, non-prefetchable) [size=4K]
      Kernel driver in use: ehci_hcd
      00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
      Flags: bus master, medium devsel, latency 0, IRQ 19
      Memory at d3407000 (32-bit, non-prefetchable) [size=128]
      I/O ports at 1000 [size=128]
      Kernel driver in use: sis190
      Kernel modules: sis190
      00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03) (prog-if 8f [Master SecP SecO PriP PriO])
      Flags: bus master, medium devsel, latency 32, IRQ 17
      I/O ports at 10a0 [size=8]
      I/O ports at 1094 [size=4]
      I/O ports at 1098 [size=8]
      I/O ports at 1090 [size=4]
      I/O ports at 1080 [size=16]
      Kernel driver in use: sata_sis
      Kernel modules: sata_sis
      00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge (prog-if 00 [Normal decode])
      Bus: primary=00, secondary=04, subordinate=05, sec-latency=0
      I/O behind bridge: 00003000-00004fff
      Memory behind bridge: dc000000-dfffffff
      Prefetchable memory behind bridge: 00000000d3200000-00000000d33fffff
      00:07.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge (prog-if 00 [Normal decode])
      Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
      Memory behind bridge: d3100000-d31fffff
      00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
      Flags: bus master, medium devsel, latency 0, IRQ 18
      Memory at d3400000 (32-bit, non-prefetchable) [size=16K]
      Kernel driver in use: HDA Intel
      Kernel modules: snd-hda-intel
      01:00.0 VGA compatible controller: nVidia Corporation GT218 [GeForce 310M] (rev a2) (prog-if 00 [VGA controller])
      Flags: bus master, fast devsel, latency 0, IRQ 16
      Memory at d2000000 (32-bit, non-prefetchable) [size=16M]
      Memory at c0000000 (64-bit, prefetchable) [size=256M]
      Memory at d0000000 (64-bit, prefetchable) [size=32M]
      I/O ports at 9000 [size=128]
      [virtual] Expansion ROM at d3080000 [disabled] [size=512K]
      Kernel driver in use: nouveau
      Kernel modules: nouveau, nvidiafb
      01:00.1 Audio device: nVidia Corporation High Definition Audio Controller (rev a1)
      Memory at d3000000 (32-bit, non-prefetchable) [size=16K]
      03:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller (rev 20)
      Memory at d3100000 (32-bit, non-prefetchable) [size=256]
      Kernel driver in use: sdhci-pci
      Kernel modules: sdhci-pci
      03:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller (rev 20) (prog-if 01)
      Flags: fast devsel, IRQ 16
      Memory at d3100400 (32-bit, non-prefetchable) [size=256]
      03:00.3 System peripheral: JMicron Technology Corp. MS Host Controller (rev 20)
      Memory at d3100800 (32-bit, non-prefetchable) [size=256]
      Kernel driver in use: jmb38x_ms
      Kernel modules: jmb38x_ms
        Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 001 Device 003: ID 1871:0306 Aveo Technology Corp.
        Bus 001 Device 002: ID 0bda:8189 Realtek Semiconductor Corp. RTL8187B Wireless 802.11g 54Mbps Network Adapter
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          That is very new hardware.
          I still suspect a power management issue, and possibly the nouveau driver is not able to handle all the power management features of the Nvidia GF310M. I don't know -- I don't have access to that chip. If you don't mind risking an experiment, you could go into System > Additional Drivers and enable the proprietary Nvidia driver. I cannot guarantee any improvement -- it could get worse, or no better. Best to back up your data first, of course. Note that after you click the "accept" (or whatever) button to enable the proprietary driver, there is a lengthy process of downloading in the background, so you must be very patient for as long as 5 minutes, depending on your Internet connection bandwidth.
            I have tried installing the Nvidia-current and blacklisting nouvea before. All I got was a failing x and fell back to tty login. Googling this it seems the latest nvidia drivers "dropped support" for the 310m, although this may be an accidental regression.
              Ahhh - yes, I see. Did you try anything like the last post here?: http://ubuntuforums.org/showthread.php?t=1392766&page=4
              That's for a Sony Vaio, but the basic procedure might work for your laptop as well.
                Yikes! I'll have a go when I've got some time spare. For the moment I can live with having to plug in.
