Extremely slow system
    Hi
    I have updated my laptop to 10.10.
    No problems with the updates, bu after reboot the system runs extremely slow.
    The Launch K and all the bar doesn't work. The cpu cooler is working at full speed...
    I can only execute browser and other things using ALT+F2.
    What can it be?
    Thanks
    Re: Extremely slow system
    Hmmm I don't know about your issues with the k menu and the bar.
    does ctrl+esc indicate that there is a process hogging your cpu?
    Home: Kubuntu 12.04-amd64; Intel i7-860 on Intel DH55PJ; Nvidia 9500GT; 6GB RAM
    Network Slave: Xubuntu 11.10-x86; Intel P4-Prescott on MSI; 2GB RAM; Nvidia FX5200
    Portable: Xubuntu 11.10-amd64; Asus EeePC 1015PEM
      I think have the same problem.
      Starting of details:
      lspci | grep nvidia
      01:00.0 VGA compatible controller: nVidia Corporation G72M [Quadro NVS 110M/GeForce Go 7300] (rev a1)
      nvidia-smi Timestamp: Wed Oct 13 08:39:53 2010; Driver Version: 260.19.06
      KDE 4.5.1
      Linux goociolap 2.6.35-22-generic #34-Ubuntu SMP Sun Oct 10 09:24:00 UTC 2010 i686 GNU/Linux
      and the rest:
      I have a very poor performance of the KDE env. Very high CPU usage on a process of kwin (about 30-40 percent).. BUT...! When I disable "desktop effects", everything works super fast - as it should.
      I suppose that the problem is the nvidia drivers, or something at the interface between the driver / library of desktop effects.
        Something like that can happen when you upgrade kde so if your upgrade took you up a version of KDE it can be worth renaming /home/.kde/share/config.
        It will reset your desktop which you will need to reconfigure but it might be worth a shot.
          Run Alt-F2 "konsole" with no quote marks to open the Konsole, aka terminal. In the terminal, run
          htop
          and this will show the running processes, in descending order of resource consumption.
          There was a kernel update last evening -- make sure your system is updated.
          Nvidia driver 260.19.06 is running well on my GTX260, but it is a beta driver. You might want to go back and try the official released driver, just in case that is the issue.
            Yep.
            I had the same or similar issues when "jumping" from one version of KDE4.x to another.
            some times panels, widgets and activities overlap each other.
            The complicated way:
            First make sure that desktop effects are turned off.
            Then delete the panel at the bottom with:
            right click on desktop->unlock widgets if they are locked.
            Right click on the bottom panel and choose remove panel.
            Now get rid of all the widgets by mouse over -> click on the "X" that appears in the sliding configuration panel.
            Finally delete all activities except for one.
            Log out / log in and you should a virgin desktop.
            If needed you can now add a new default panel with:
            right click desktop->add panel->default panel.
            Add your widgets as needed.
            The less complicated method:
            open a terminal or do alt+f2 and type:
            sudo stop kdm
            Now do what the liquidator suggested:
            mv /home/yourusername/.kde/share/config /home/yourusername/.kde/share/configOld
            Now restart kwin:
            sudo restart kdm
            I hope that helps
            4 GB Ram
            Kubuntu 18.10
              Solved.
              The problem was really the .kde config folder. After renaming, start to work normal now.
              Thank You.
