After installation problem - adding /home back to fstab
    Hi!
    Thanks again for being an awesome site. I tried to delete an earlier thread as I came across an install disk and decided it would be helpful to do a clean install.
    I got an error during installation when I tried to use my previous /home partition as my /home partition without formatting on my new install. I believe this is a bug...but we can figure out that later.
    So my install was successful, and right now, the current /home directory just sits on the / partition. How do I fix this so that my previous /home partition is now mounted correctly as /home and added to the fstab in a proper way?
    Thanks for your help!
    Re: After installation problem - adding /home back to fstab
    An easy way would be something like this added to /etc/fstab
    /dev/sda3 /home ext3 errors=remount-ro 0 1
    You may need to change sda3 to sda5 or sdb3 or whatever your partition should be.
    If you prefer to use the UUID instead of the /dev option, run blkid to get the specific one for that partition.
    Multibooting: Kubuntu Noble 24.04
    Before: Jammy 22.04, Focal 20.04, Precise 12.04 Xenial 16.04 and Bionic 18.04
    Win XP, 7 & 10 sadly
    Using Linux since June, 2008
      Couple of things here -
      Just so I'm straight on the issue: you have a /home partition that you used during a previous install that is not being mounted as /home and you want to do that? If you have nothing much in the way of files in your /home thats under root just:
      Edit /etc/fstab adding the /home partition
      Log out
      hit Alt-f1 and log in
      do "sudo mount -a"
      hit alt-f7 and log back in.
      should be good to go.
      There will be config files left behind and hidden in /home under /, but it's not a ton of data. If you need to want to delete or access them, use the live cd is the easiest way. Boot to it and mount your / partition, rename /home to something else and create a new /home and reboot back to your install.
        Thanks for chiming in oshunluvr. Thank again for your help on all the RAID stuff a few weeks back. It looks like I have to hit you up again for some advice/help.
        Keep in mind, the last time I backed up was about 2 weeks ago. I think I might have lost some data - but not too much.
        Previously, when we were messing with my RAID stuff, I had set up my 2nd hard drive to be identical - and did a full backup then. Back then, my primary drive was /dev/sda and my second was /dev/sdb.
        During the install, I had asked for /dev/sda to be my main drive as before, and had asked for /dev/sdb to be formatted [this is where I messed up]. I did like you just mentioned and added my /home partition back, but stuff didn't look quite right. The time stamps looked a little bit old. My heart started pounding as I realized that my previous /dev/sdb has become my /dev/sda and my original /dev/sda is now formatted.
        Now, the formatting was done by the install utility. Nothing has been written back since then. I do have a copy of my previous MBR. Is it possible to copy the MBR [or something like that] back to the old drive and get everything back the way it was?
        Or am I screwed?
          Ok...used test disk to go through the old disk. It looks like everything is still there - at least the filenames are.
          Is there anything I should be careful with?
            Funny, I just went through something similar this weekend. I had 2tb of video at risk and didn't lose a frame.
            You can rewrite the MBR if you still have the file:
            dd if=PATHTOFILE of=/dev/sda
            this assumes you have the 512b whole MBR and not just the partition table, which only 64b.
            I had more problems than just a deleted partition - I had overlapping partitions that I had to fix.
            Try restoring the old MBR first. If that doesn't work right away - don't panic. Until you overwrite the data there's a very good chance we can still get to your data.
            If this fails, examine the disk with "testdisk" - it will run a while but may very likely find your partition(s) for you. Post back and I'll give more details if needed.
              Basically, if testdisk can find the partition geometry - cylinders, heads, starting sector, ending sector...
              you can use fdisk to recreate your partition table manually. Then, you run file check on the restored partitions to verify all is well - but run with the --check option. You don't want anything written at this stage.
                 Linux          0  1 1  242 254 59  3903728
                 Linux Swap       243  0 1 3889 254 40  58589032
                 Linux         3890  0 1 34283 254 61 488279608
                 Linux        34284  0 1 121600 254 58 1402747600
                OK. The testdisk analyzer is still running, but these are all of the partitions. I went through earlier, and it looks like the filenames are in tact. So basically, I should just be able to write this down into the partition table [same thing as the MBR, right?], remount everything, and I should be solid, right?
                Can you give me some more direction about recreating my partition table using fdisk and then checking the restored partitions? Thank you a lot!
                  Looks like you've got double listings. I see these four partitions;
                              start     end  size in sectors
                  I appears they're all primary? What is the output of sudo fdisk -l /dev/sda
                    sudo fdisk -l /dev/sdb is from the disk that is having trouble. This is the one that used to be /dev/sda on my previous installation.
                    $ sudo fdisk -l /dev/sdb
                    Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
                    255 heads, 63 sectors/track, 121601 cylinders
                    Units = cylinders of 16065 * 512 = 8225280 bytes
                    Disk identifier: 0x00000000
                    Disk /dev/sdb doesn't contain a valid partition table
                    But, since you asked, from /dev/sda [which used to be /dev/sdb and contains a backup from a couple of weeks ago]:
                    $ sudo fdisk -l /dev/sda
                    Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
                    Disk identifier: 0x00040b2b
                      Device Boot   Start     End   Blocks  Id System
                    /dev/sda1  *      1     243   1951866  83 Linux
                    /dev/sda2       244    3890  29294527+ 82 Linux swap / Solaris
                    /dev/sda3      3891    34284  244139805  83 Linux
                    /dev/sda4      34285   121601  701373802+ 83 Linux
                    I guess what I would like to do is get /dev/sdb up and running again, and if possible, make it my primary hard drive - like it used to be. However, I guess I could rsync them together again and it wouldn't make that much difference.
                      Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121602 255 63
                         Partition        Start    End  Size in sectors
                      * Linux          0  1 1  242 254 63  3903732
                      P Linux Swap       243  0 1 3889 254 63  58589055
                      P Linux         3890  0 1 34283 254 63 488279610
                      P Linux        34284  0 1 121600 254 63 1402747605
                      Just finished running the analyze part of testdisk and this is the output.
                        After running testdisk, I let it try to write the partition table, and it worked!
                        Now...and this is more minor. What is the best way to sort of back up my current hard drive with the more recent files from the other hard drive? I think that it might only be a handful of files, but I want to be sure before moving on.
                        Thanks again for all of your help.
                          Great! that was easy whew! and you're right, I got confused with all the drive switching... lol
                          As far as your last post: I'm confused again. It sounds like you have some files you've updated on one drive and you want to duplicate them on the other one so they're both the same. Is that right?
                          Before you do anything, I'd take the time to verify your file systems are all OK. I assume you're still using ext4? If so, fsck will check your partitions.
                          I'm sure there's some zippy utility out there that will locate your newer files for you. Do you know what date/time you would consider new enough to at least look at? If so the find utility works great. You can use kfind from the GUI or find at the command line and get a list of what files have been modified since whenever. Then review and copy those you deem worthy.
                            Got it. Thanks for your help. fsck did fine.
                            Tell me one more thing. How can I make it so that this doesn't happen again? What makes one particular hard drive sda one time and sdb another? I would really like to sort that out. Thanks!
                              I wish I had a good answer. Usually, the bios determines the drive order and most modern bios's (bioii ?) will have the ability to re-arrange this as you see fit.
                              Many OS's and/or installers will assign sda to the first drive it sees, which might not be the first drive in the bios. Often it's the drive you booted to or possibly even the drive you ask it to install to. I'm not really sure how to control it.
                              I just tried to do a new install of 10.10 and it identified my drives as sda, sde, sdf, sdg for no apparent reason.
                              Since we have identical drives (in my case 4), it can get tricky. All I can say is proceed very slowly. I use partition labels on many of my partitions, which the kubuntu installer sees so I am sure which is which. Another solution is to not use the exact same partitioning scheme on both drives.
