I did the dist-upgrade with the alternate disk to save some headaches.
Did use internet support instead of disk only.
First reboot and nothing - xserver crashed.
Went back to grub and added nomodeset to first used kernel 2.6.35.22 - still nada.
Back to grub and used 2nd kernel with nomodeset - SUCCESS!
Ran synaptic and checked if the Kernel headers for 2.6.35.22 were installed - NO!
Installed the Kernel headers, and without the nomodeset - SUCCESS!
( this happened before with a previous Kernel update - the headers were not included)
I'm using Nvidia graphics with the 173 driver, and so far so good.
Check this out if you have the same.
