Audio problem
    Re: Audio problem
    kevin@kevin-desktop:~$ lspci -vv
    00:00.0 Host bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 01)
        Subsystem: Dell Device 0142
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
        Latency: 0
        Region 0: Memory at e8000000 (32-bit, prefetchable) [size=128M]
        Capabilities: <access denied>
        Kernel driver in use: agpgart-intel
        Kernel modules: intel-agp
    00:01.0 PCI bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE Host-to-AGP Bridge (rev 01) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 64
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
        Memory behind bridge: fc000000-fdffffff
        Prefetchable memory behind bridge: f0000000-f7ffffff
        Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA+ VGA+ MAbort- >Reset- FastB2B-
            PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Kernel modules: shpchp
    00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 16
        Region 4: I/O ports at ff80 [size=32]
        Kernel driver in use: uhci_hcd
    00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin B routed to IRQ 19
        Region 4: I/O ports at ff60 [size=32]
    00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin C routed to IRQ 18
        Region 4: I/O ports at ff40 [size=32]
    00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin D routed to IRQ 23
        Region 0: Memory at fe300000 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ehci_hcd
    00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 81) (prog-if 00 [Normal decode])
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR+ INTx-
        Latency: 0
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
        I/O behind bridge: 0000e000-0000efff
        Memory behind bridge: fe100000-fe2fffff
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA+ VGA- MAbort- >Reset- FastB2B-
    00:1f.0 ISA bridge: Intel Corporation 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge (rev 01)
        Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 0
        Kernel modules: iTCO_wdt, intel-rng
    00:1f.1 IDE interface: Intel Corporation 82801DB (ICH4) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 18
        Region 0: I/O ports at 01f0 [size=8]
        Region 1: I/O ports at 03f4 [size=1]
        Region 2: I/O ports at 0170 [size=8]
        Region 3: I/O ports at 0374 [size=1]
        Region 4: I/O ports at ffa0 [size=16]
        Region 5: Memory at 30000000 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ata_piix
    00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
        Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin B routed to IRQ 11
        Region 4: I/O ports at dc80 [size=32]
        Kernel modules: i2c-i801
    01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 420] (rev a3) (prog-if 00 [VGA controller])
        Subsystem: nVidia Corporation Device 015a
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 64 (1250ns min, 250ns max)
        Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
        Region 1: Memory at f4000000 (32-bit, prefetchable) [size=64M]
        Region 2: Memory at f3f80000 (32-bit, prefetchable) [size=512K]
        Expansion ROM at f0000000 [disabled] [size=128K]
        Kernel driver in use: nouveau
        Kernel modules: nouveau, nvidiafb, rivafb
    02:01.0 Ethernet controller: Atheros Communications Inc. AR5007G Wireless Network Adapter (rev 01)
        Subsystem: Belkin Device 720b
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 168 (2500ns min, 7000ns max), Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 22
        Region 0: Memory at fe1f0000 (32-bit, non-prefetchable) [size=64K]
        Kernel driver in use: ath5k
        Kernel modules: ath5k
    02:02.0 Multimedia audio controller: Creative Labs [SB Live! Value] EMU10k1X
        Subsystem: Creative Labs Device 1003
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 64 (500ns min, 5000ns max)
        Region 0: I/O ports at ece0 [size=32]
        Kernel driver in use: EMU10K1X
        Kernel modules: snd-emu10k1x
    02:02.1 Input device controller: Creative Labs [SB Live! Value] Input device controller
        Latency: 64
        Region 0: I/O ports at ecd8 [size=8]
        Kernel driver in use: Emu10k1_gameport
        Kernel modules: emu10k1-gp
    02:08.0 Ethernet controller: Intel Corporation 82801DB PRO/100 VE (LOM) Ethernet Controller (rev 81)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 64 (2000ns min, 14000ns max), Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 20
        Region 0: Memory at fe1ef000 (32-bit, non-prefetchable) [size=4K]
        Region 1: I/O ports at ec80 [size=64]
        Kernel driver in use: e100
        Kernel modules: e100
    02:0c.0 FireWire (IEEE 1394): Texas Instruments TSB12LV26 IEEE-1394 Controller (Link) (prog-if 10 [OHCI])
        Subsystem: Dell Device 8010
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 64 (750ns min, 1000ns max), Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at fe1ee800 (32-bit, non-prefetchable) [size=2K]
        Region 1: Memory at fe1e8000 (32-bit, non-prefetchable) [size=16K]
        Kernel driver in use: firewire_ohci
        Kernel modules: firewire-ohci, ohci1394
      Re: Audio problem
      OK, the EMU10k1X is the only sound chip on your system.
      Hmmmmm. I wonder why that snd-emu8000-synth.ko is loading. It should not hurt to remove it with
      sudo rmmod snd-emu8000.synth
      What are you using to test the sound output? Do you have a music .wav file to play?
        Re: Audio problem
        Okay, I tried to do that, and I got this:
        kevin@kevin-desktop:~$ sudo rmmod snd-emu8000.synth
        ERROR: Module snd_emu8000 does not exist in /proc/modules
