Hi, I'm trying to install Kubuntu 10.04 on my new notbook Samsung N150 from an USB device. I already have installed kubuntu 10.04 on other netbooks without problems with the same USB device. Now, after the splash screen, which seems to bo regular, I get a terminal (in all tty, even in 7th tty). I tried to make serverx run with
serverx
but the only thing I get was
Fatal error:
Cannot open log file "/var/log/Xorg.0.log"
In addition to that, sometimes the terminal gives me this error message:
[...] EXT3.fs error (device loop1): ext3_add_entry: bad entry in directory #2049: directory entry across block - offset=0 inode=..., rec_len=..., name_len...
Please, help me, thanks
serverx
Fatal error:
