Some post-installation bugs with resolution and bottom panel
    Hello guys!
    3 days ago I have installed Kubuntu 10.04, and I must say that I am impressed a lot how beautiful it is. Everuthyng is cool, except couple of things, and I am asking for your help to solve them out.
    1. I had a resolution problem, that was in not remembering the resolution I selected, and reverting back to 800x600 just after I reboot. So I have found the solution here and it works just fine after I enter my login details. But in the login screen I get this:
    As you can see I have a login box somewhere in the top left corner, as well as the background picture, as if they were tiled because of new higher resolution set. So, is there a way to fix it, so that login box would be in the center of the screen, and background would be placed correctly?
    2. Just after I log in my bottom panel looks like this:
    On this picture you can see that the panel have some weird black background in the left half of it, and normal one in the right half. And if I change it's size just a little bit, so that it cover not the whole available width, the background of the panel returns to normal.
    I would be highly appreciated for any help. Thank you!
    Re: Some post-installation bugs with resolution and bottom panel
    Seems the swapping resolutions messed with your splash...
    I'd be interested to see a part of /usr/share/kde4/apps/kdm/themes/ethais/ethais.xml
    Open this file with kate or kwrite and look at lines 14-17. Somewhere there should be
    <normal file="wallpapers/background.png" scalemode="crop"/>
    If it says "tile" instead of "crop", you've found it.
    You might just try opening System Settings > Appearance > Splash Screen and select "simple", apply, then re-select "Default" and apply
      no, it says "crop". As I understand this settings apply on the screen just after I enter my password and press entre.
      But there everything looks OK, the problem is only at the screen where I enter login and password.
      I believe the problem is somewhere in kdm...
      Here's what this file have inside:
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE greeter SYSTEM "greeter.dtd">
      <greeter id="theme">
      	<style font="Sans 12" window-text-color="#bfd9ff"
      	    base-color="#bfd9ff" alternate-base-color="#666666"
      	    text-color="#0b678c" disabled-text-color="#333333"
      	    base-alpha="0"
      	    disabled-base-color="#ff0000"
      	    disabled-base-alpha="0.25"
      	    disabled-highlight-alpha="0"
      	    frame="false" />
      	<item type="pixmap" id="background" background="true">
      		<pos x="0" y="0" width="100%" height="100%"/>
      	</item>
      	<item type="pixmap" id="system-session">
      		<normal file="rectangle.png"/>
      		<pos anchor="c" x="50%" y="50%" width="416" height="262"/>
      	</item>
      	<item type="pixmap" id="branding-logo" background="true">
      		<normal file="branding.png" alpha=".4" />
      	</item>
          <normal alpha="0.1" file="rectangle_overlay.png"/>
          <fixed>
            <item type="label" id="welcome">
              <pos anchor="nw" x="20" y="20"/>
              <normal alpha="0.75" font="Sans Bold 14" color="#0b678c"/>
              <text>%h</text>
            </item>
          </fixed>
        </item>
      	<item type="rect">
          <pos anchor="c" x="50%" y="50%" width="200" height="100"/>
      		<box orientation="vertical" spacing="10" homogeneous="true">
      			<item type="rect" id="user-field">
      				<pos anchor="c" x="50%" y="50%" width="200" height="box"/>
      				<fixed>
                <item type="pixmap">
                  <pos anchor="w" x="0" y="50%"/>
                  <normal file="user_icon.png"/>
                </item>
                  <pos anchor="w" x="42" y="50%"/>
                  <normal file="lineedit_normal.png"/>
                  <prelight file="lineedit_active.png"/>
                  <active file="lineedit_active.png"/>
                </item>
                <item type="entry" id="user-entry">
                  <pos anchor="w" x="49" y="50%" width="140" height="20"/>
                </item>
              </fixed>
            </item>
            <item type="rect" id="user-field2">
              <fixed>
                <item type="pixmap" button="true">
                  <pos anchor="w" x="0%" y="50%"/>
                  <normal file="lock.png"/>
                </item>
                </item>
                <item type="entry" id="pw-entry">
                </item>
              </fixed>
            </item>
      		</box>
      	</item>
      	<item type="rect" id="system-session">
          <fixed>
            <item type="label">
              <pos anchor="se" x="-15" y="-20"/>
              <normal font="Sans Bold 8" color="#0b678c"/>
              <text>%c</text>
            </item>
            <item type="pixmap" id="session_button" button="true">
              <normal alpha="0.8" file="session_normal.png"/>
              <prelight file="session_normal.png"/>
              <active file="session_normal.png"/>
              <pos anchor="sw" x="22" y="-20"/>
            </item>
            <item type="pixmap" id="system_button" button="true">
              <normal alpha="0.8" file="system_normal.png"/>
              <prelight file="system_normal.png"/>
              <active file="system_normal.png"/>
              <pos anchor="sw" x="50" y="-20"/>
            </item>
            <item type="pixmap" id="login_button" button="true">
              <normal file="login_normal.png"/>
              <prelight file="login_active.png"/>
              <active file="login_active.png"/>
              <pos anchor="e" x="-20" y="50%"/>
            </item>
          </fixed>
        </item>
      	<item type="rect" id="caps-lock-warning">
          <fixed>
            <item type="label" id="mesage">
              <normal color="#0b678c" font="Sans Bold 10"/>
              <pos anchor="s" x="50%" y="80%"/>
              <stock type="caps-lock-warning"/>
            </item>
          </fixed>
      	</item>
      	<item type="rect" id="pam-error-paceholder">
      	<pos anchor="c" x="50%" y="98%" widht="615" height="200"/>
      		<item type="label" id="dummy1">
      			<normal alpha="0" color="#0b678c" font="Sans Bold 10"/>
      			<!-- </text> -->
      		</item>
      		<item type="label" id="pam-error">
      			<pos anchor="c" x="50%" y="50%" expand="true"/>
      			<!-- </text> -->
      		</item>
      	</item>
      </greeter>
        That file looks the same as mine - I agree it's the Greeter that is messed up, but all you have in kdmrc is
        Theme=/usr/share/kde4/apps/kdm/themes/ethais
        UseBackground=true
        UseTheme=true
        unless something changed that. I assume you've looked at the actual wallpaper to verify it's full sized?
        /usr/share/wallpapers/Ethais/contents/images/
        Should have 1920x1200.png in it and naught else.
        Did you try changing to a different greeter theme and back again?
          Just did it and it truly is 1920x1200, and it weights 1,7Mb. A believe it isn't wallpaper problem because of my login box is located in the top left corner, not in the middle of a screen (have a look at the first screen). Something in the system still thinks I have 800x600 screen, and tiles everything, including the login box, and a wallpaper, that actually is already 1920x1200 of a size.
          In the KDM settings (under System Settings -> Advanced -> Login manager -> Theme I only have one theme called Ethais. Maybe what you mentioned as "Greeter theme" should be changed somewhere else?
