Hi There,
I installed the 10.04 on a Clevo-901c with 4G ram.... I created 2 users lets name them x and y.
User x is a administrator and worked fine till 2 days ago...when I start user x the system loads normally till the 5th icon appears then it takes 10 times longer to load user x then user y.
clicking on a desktop symbol is only possible once. The system still has a lot of resources free if I read top or "ctrl esc" well.
But the system x seems very slow overall....
On the other hand I created a new user "y" after the incident which works as one can expect.
Has this something to do with the memory of which applications where loaded during the earlier session?
So may question is how do I resolve this unresponsiveness for user x?
Can I turn of the memory of which applications that where running?
Kind Regards
Guy Forssman
Kind Regards
Guy Forssman
