Hi all,
I upgraded from jaunty to lucid (64bis) and I have an NVIDIA video card.
upon rebooting I got to the login screen, but when I tried to log in, KDe aborted after a few seconds and said "can't start ksmserver - check your installation" (or something to that effect), and threw me back to the login screen.
It turns out this is a problem with the proprietary NVIDIA driver; you just have to delete some old libs:
(be careful with the dot '.'! or you delete more than you should.)
I found the solution here:
http://ubuntuforums.org/showthread.php?t=1467087
It worked for me and I thought I might save others some time by posting it here (it took me some time to find this anyway...)
Otherwise the upgrade went well.
Chopstick
cd /usr/lib/ sudo rm libGL.*
Chopstick
