Yesterday while working with Kubuntu 9.10 I got a message asking if I wanted to upgrade to 10.4. Without thinking, I selected "yes". Big mistake! After about 2 hours the "upgrade" was complete. My Internet connection was wiped out and my TouchPad was turned on. I had previously turned it off. It took a few hours to get these problems solved. Now, upon startup it doesn't always complete the startup. Then I have to reboot and hit F12. Then I can select boot from HHD and it will boot up. Every time I boot up I get lots of text before it goes into graphical mode. Then, once running, it tends to freeze up and I have to power down and reboot.
I'm inclined to reinstall Kubuntu 9.10 but that will be a pain too since everything will have to be set up again.
What to do? Is there a fix for 10.4 that will make it run smoothly or would I be better off going back to 9.10?
Thanks in advance for your help!
