I have upgraded from 9.10 into 10.04 and I have problem with updates now,
Also, firefox is always offline, so when I start it first I have to go file- and deselect work offline.
Thanks for your support.
Error Type:
Error Value: coercing to Unicode: need string or buffer, exceptions.SystemError found
File : /usr/share/PackageKit/helpers/apt/aptBackend.py, line 2216, in
main()
File : /usr/share/PackageKit/helpers/apt/aptBackend.py, line 2213, in main
run(args, options.single)
File : /usr/share/PackageKit/helpers/apt/aptBackend.py, line 2175, in run
backend.dispatcher(args)
File : /usr/lib/python2.6/dist-packages/packagekit/backend.py, line 699, in dispatcher
self.dispatch_command(args[0], args[1:])
File : /usr/lib/python2.6/dist-packages/packagekit/backend.py, line 606, in dispatch_command
self.refresh_cache(force)
File : /usr/share/PackageKit/helpers/apt/aptBackend.py, line 202, in _locked_cache
func(*args, **kwargs)
File : /usr/share/PackageKit/helpers/apt/aptBackend.py, line 1498, in refresh_cache
format_string(error.message))
File : /usr/lib/python2.6/dist-packages/packagekit/backend.py, line 723, in format_string
txt = unicode(text, encoding, errors='replace')
main()
