Wifi not working after hybarnate
    Have been using ubuntu since 9.04
    Switched to kubuntu netbok remix and have a big problem. Did a fresh install and everything worked fine (on my Vaio UX50 UMPC) small work around sound but other than that a perfect system. This morning it hibernated and when it came out the wifi just stopped working. Soft reset does not help. Maybe the powersaving feature messed with it i have no idea. I use Intel PRO Wireless 3945ABG-BG
    Any help would be appreciated.
    Re: Wifi not working after hybarnate
    Let's just ensure, for now, that the wireless still works. So, do a full reboot and verify that your wireless still works correctly after you've logged on.
      Thats a negative. The wifi/bluetooth switch does not power on wifi either. I does do bluetooth still.
      Wifi worked natively under linux since 9.04 so i have no idea what the problem is.
        This line of code seemed to fix it.
        sudo ifconfig wlan0 up
        Now how do i make this permenant on startup? I could make a shell script but thats the messy way arround.
          scrach that the light comes up but nothing else works. If i highlight the wireless manager it shows up as "unmanaged" and when i click it it runs konquror.
            service network-manager stop
            rm /var/lib/NetworkManager/NetworkManager.state
            service network-manager start
            Here is the fix that worked for me.
