[SOLVED] mysql problem after upgrade
    Hello, I upgraded from 9.10 to 10.04. 32 bit.
    The install had not finished as it barked at tripwire config. I have had to stop it and continue from command prompt.
    After the install, mysql 5.1 does not want to start or stop.
    /etc/init.d/mysql stop
    /etc/init.d/mysql start
    do not finish. Tried to remove and reinstall the packages, the same (there is 'stop mysql' command in one of install scripts).
    Please help.
    Re: mysql problem after upgrade
    When you continued from the command prompt, did you do both:
    sudo apt-get install -f
    sudo dpkg --configure -a
      of course.
      Solved: the problem was caused by symlink from /etc/mysql/conf.d to config file in home directory!
