HELP Sound Shuttering kubuntu 10.04
    The problem is when i am using the laptop for a long time. The sound shutters and slows down the laptop. This happens on all programs. Wine amarok kubuntu sounds. I have updated to the new pae kernel. I need to have this issue fixed or i will have to go back to 9.10 untill this issue is fixed. Any help is greatly needed. Also there is no sound in flash on any web browsers. Also i need this fixed also.
    Thanks
    Shawn
    Re: HELP Sound Shuttering kubuntu 10.04
    Can you define "sound shutters"? Also, what is "the new pae kernel"? I'd like to help, but I'm an old geezer and I need a translation!
    Also:
    Have you activated the medibuntu repositories?
    Can you describe your hardware?
      I can when i get home not at the laptop now.
        The new pae kernel is for the server version of ubuntu. As far as the shuttering. When i am at the laptop and have it running for several hours and have music going i start to get the shuttering or when i play a video. Also when i lock the machine i get the shuttering. Also the flash sound does not work in any web browsers.
        Here is my current kernel
        Linux angless 2.6.31-22-generic-pae #60-Ubuntu SMP Thu May 27 01:40:15 UTC 2010 i686 GNU/Linux
        Here is my config
        00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
        00:01.0 PCI bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express PCI Express Root Port (rev 03)
        00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
        00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
        00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01)
        00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 01)
        00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
        00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01)
        00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01)
        00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01)
        00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
        00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
        00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01)
        00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 01)
        00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
        01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility X1400
        03:00.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
        03:01.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller
        03:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 19)
        03:01.2 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 0a)
        03:01.3 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 05)
        03:01.4 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev ff)
        0c:00.0 Network controller: RaLink RT2860 Wireless 802.11n PCIe
          I still have absolutely no idea what you mean by "shuttering". Is something changing in a (quasi)periodic way? If so, what: volume, pitch (frequency), frequency range, or something else? If that's not what you mean, please explain what you hear without using the word "shuttering".
          Second, why are you using a server kernel on a laptop? What else is your laptop doing besides playing music and video? Most laptops don't have the hardware to run as servers. The equipment list you provided seems fairly standard for a laptop, so I wonder why you aren't using a standard user oriented version of the OS. As a related question, how much RAM do you have?
          I also notice that you seem to be using the built-in Intel sound chip. Does your laptop have an internal speaker, or are you feeding audio signals to an external speaker system? If so how is your audio system connected to the laptop? It may be that your connection is causing problems.
            I have 2 gig of ram in the laptop. Also i found out that the pae kernel is leaner and faster than the orginal generic kernel. Also my sound is by laptop speakers and some times a tv is pluged in to the laptop. The shuttering happens when i am playing music and the sound comes out garbled. I wished i had recorded a sample of when this happens. I also have the generic kernel install also.
              I would try using the generic kernel just to see if it makes a difference.
                I can try when i reinstall the new version. I had to down grade to 9.10 for the mean time.l
