I recently purchased a used machine that appears to have a RV530LE graphics card in it. I also have a KDS Monitor. At resolution 1280x1024 (Auto/75.0Hz) I can expect the display to start waving, moving sine wave about a centimeter most noticeable along windows borders.
When I go into KDE's "System Settings" -> "Computer Administration" -> "Display" -> "Size & Orientation", looking under VGA-0 (Connected) I see size (refresh) as follows: 720x400(Auto/70.1Hz), 640x480(Auto/60Hz/85.0Hz), 800x600(Auto/60.3Hz/75.0Hz/85.1Hz/100Hz), 1024x768(Auto/60Hz/75.1Hz/85.0Hz), 1280x1024 (Auto/75.0Hz) and lastly Disabled.
When I set the display at the highest 1280x1024 (Auto/75.0Hz), after a period of time the edges of the display windows have the appearance of waves. Also when shut down the setting is not retained, requiring that the display be reset to the 1280x1024 (Auto/75.0Hz). Lastly after using the high resolution setting, occasionally when the machine is restarted it comes up with a white screen. Neither waves or white screen occur at the 1024x768(Auto/60Hz/75.1Hz/85.0Hz) or lower resolutions.
On my other machine using the same monitor I thought I had more video SVGA resolution options / frequencies to choose from, believe that was an NVIDIA card. I assume that I may be missing a driver or two or picked the wrong ones. If my problem was hardware failure I would expect display symptoms to appear with all settings.
Thanks for any assistance, this large screen is irritating,
Scott
Below are some more details:
I downloaded the Kubuntu ATI drivers from the repository:
xserver-xorg-video-radeonhd-dbg - 1.3.0-2(amd64)
xserver-xorg-video-radeonhd - 1.3.0-2 (amd64)
Kubuntu
Distributor ID: Ubuntu
Description: Ubuntu 10.04 LTS
Release: 10.04
Codename: lucid
KDS Monitor
Product Number XF-9i
Model 986N
Product Series DZ-987NS
Information collected by "Hwinfo"...
40: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.318]
UDI: /org/freedesktop/Hal/devices/pci_1002_71ce
Unique ID: VCu0.Yo0WargBqpA
Parent ID: 8otl.eXkdSneG_FF
SysFS ID: /devices/pci0000:00/0000:00:04.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "ATI RV530LE [Radeon X1600]"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x71ce "RV530LE [Radeon X1600]"
SubVendor: pci 0x174b "PC Partner Limited"
SubDevice: pci 0x0840
Driver: "radeon"
Driver Modules: "drm"
Memory Range: 0xe0000000-0xefffffff (rw,prefetchable)
Memory Range: 0xfdef0000-0xfdefffff (rw,non-prefetchable)
I/O Ports: 0xac00-0xacff (rw)
Memory Range: 0xfdec0000-0xfdedffff (ro,prefetchable,disabled)
IRQ: 26 (13433 events)
I/O Ports: 0x3c0-0x3df (rw)
Module Alias: "pci:v00001002d000071CEsv0000174Bsd00000840bc03sc0 0i00"
Driver Info #0:
Driver Status: radeon is active
Driver Activation Cmd: "modprobe radeon"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #21 (PCI bridge)
41: PCI 100.1: 0380 Display controller
UDI: /org/freedesktop/Hal/devices/pci_1002_71ee
Unique ID: NXNs.ZiEoT7z6JVE
SysFS ID: /devices/pci0000:00/0000:00:04.0/0000:01:00.1
SysFS BusID: 0000:01:00.1
Model: "ATI Display controller"
Device: pci 0x71ee
SubDevice: pci 0x0841
Memory Range: 0xfdee0000-0xfdeeffff (rw,non-prefetchable)
Module Alias: "pci:v00001002d000071EEsv0000174Bsd00000841bc03sc8 0i00"
Scott
Kubuntu
Release: 10.04
Codename: lucid
KDS Monitor
Model 986N
Driver: "radeon"
Driver Info #0:
Device: pci 0x71ee
