I did a clean install of 10.04. All seems well, but my laptop (clevo 870cu, Intel Core i7 720QM, nVIDIA GeForce GTX285M) crashes after several minutes (sometimes seconds) after login when it is running on battery power. Up until now it works fine when the power cord is plugged in. I also noticed that the power manager does not detect that the power cord is pulled out or plugged in when I am logged in. Only after a reboot the power manager gets it right.
In other words, when i boot on battery power and after login, I plug the AC adapter in, no crash happen, the battery is charging, but kde still thinks it is using battery power. Eusebiu has already put a post on this but I think he is not so unlucky that his laptop crashes when AC adapter is unplugged
Anyway, My major problem: laptop crashes when AC adapter unplugged, luckily it works (very nicely) when the AC adapter is plugged in.
(Sometimes the laptop awakens after a crash , get the login screen, I can login again, but also it will crash again. Mostly there is a black screen after a crash, the HDD led blinks every second and I have to turn off power.)
Any ideas, something to do with the power management...?
thanks
thanks
