Low Volume problem in 10.04
    Hello friends, i have some strange problems with low volume level in Lucid.
    It appears after upgrade, fresh installation, with old configure files from Karmic and with absolutely new user, but there are no problems with live-cd and GNOME distribution.
    KMix and alsamixer - all in max, but it looks like even urandom > dsp has the same result.
    $ lspci
    00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge Alternate
    00:02.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (ext gfx port 0)
    00:04.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 0)
    00:06.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 2)
    00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [AHCI mode]
    00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
    00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
    00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
    00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
    00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
    00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
    00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3c)
    00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
    00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller
    00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
    00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
    00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
    00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
    00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
    00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
    02:00.0 VGA compatible controller: ATI Technologies Inc M92 [Mobility Radeon HD 4500 Series]
    02:00.1 Audio device: ATI Technologies Inc RV710/730
    03:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5784M Gigabit Ethernet PCIe (rev 10)
    09:00.0 Network controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
    Any ideas?
    Re: Low Volume problem in 10.04
    Did you activate ALL of the controls in Alsamixer, and run the "Digital" control to the top of the green?
      I had the same issue...
      Open Terminal and type alsamixer
      Use your arrow keys to turn up the volumes on everything.
      However on remember it probably wont save it. You might have to redo the same thing.
      Short term problem fix.
      Let me know how it goes.
        Mixer > Settings > Configure Channels
        Add SPEAKER to te right pane.
        Rise the volume and you are ready to go.
        Let me know if works.
